Cluain
- Dec 20, 2005
- 32
Firstly, I must apologize for asking multiple questions. If anyone has the time to respond, I would be most grateful!
Can someone explain why the correction factor “F” in UG -37 is not mandatory?
Also, if one inserts, say, a hill side nozzle (tangentially& integrally) into a cylindrical shell and the long axis of the nozzle is greater than twice the short axis. Then as per UG 36(a) (1) the reinforcement across the short dimension shall be increased as necessary to provide against excessive distortion.
What code paragraphs should one use to verify that the reinforcement across the short dimension has been increased adequately? Is it here, that one uses the correction factor when calculating the short dimension?
In regards to the longitudinal shell axis; I am having difficulty understanding what the code is trying to communicate in Fig UG 37. It appears that the angle theta and the referenced correction factor have a direct relationship to the circumferential stress in a vessel. Upon initial viewing of Fig UG 37 the “X”(longitudinal shell axis) and “Y” axis are not to be confused with the “Z” axis which would typically be parallel to the long seam of a vessel.
If this were so, then a nozzle tilted 45 degrees in the “Z” axis direction( long dimension of opening parallel to long seam) would have a correction factor of "1" because the angle theta would be “0” in respect to longitudinal shell axis “X” of figure UG 37.
