Forty years ago, when I started out in the profession my first employer (where I worked for two years) had a standard practice of reducing the strength of field welds. Ever since, I have not encountered this practice. I use the same strength, regardless of whether they are shop welds or field welds. That said, it is important for engineers to consider challenges in making field welds and considering those challenges when developing details. If a field weld is impossible to make, then adding a safety factor of 2 is not going to help. In fact, if you double the size of an already difficult weld, making it twice as big only makes it twice as difficult (and expensive). If constructability considerations might result in a sloppy weld, then as an engineer who is ultimately responsible for the safety of the structure, my solution would be to reconfigure the detail, not make the weld bigger. In fact, one of the guiding principles of good weld design (that I have heard many times in many welding seminars) is to NOT arbitrarily make welds bigger than needed for strength. Consideration of constructability, weldability, fatigue, etc. during design is the key to getting the strength you need – not making the weld bigger. Likewise, requiring trained and certified welders is equally important.
In my opinion all engineers should have to opportunity to do some welding in order to understand the challenges of making good welds. (After 40 years of designing welds, I have yet to actually weld – but it’s on my bucket list!)
On a related note, I took my 11-year-old grandson to a science fair in Philadelphia a couple of weeks ago. To my surprise Lincoln Electric had an exhibit there where kids could try their hand at virtual welding with some incredibly sophisticated welding simulators! Attached is a photo of him making a virtual fillet weld. “Welders” are graded by the computer on a number of different things (speed, angle, etc.). Thank you Lincoln Electric!
