So, if a 80'x110' building had column lines and control joints on a 20' x 21.5' grid, resulting in 20 test sections of only 400+ sq.ft. each, would it be better to make the test sections boundaries at every other column line so that most sections are roughly 40'x40' at 1600 sq.ft. ? Then most sections would be greater than 25' wide, but the number of sections (for pass/fail evalation) would be reduced from 20 to either 4 or 6. Thoughts or recommendations anyone?
