Femap Fatal Error in Propeller Static analysis 1
AbdulQayyum987
MY
Hi all,
I wanna ask if any of you would be able to help me in analyzing this propeller model. I spent days pre-processing the model before I got a fatal error as I started analyzing.
Please find the neutral file below.
Qayyum
 https://files.engineering.com/getfile.aspx?folder=4fd84a60-3e3d-4058-abc6-05ba07b3dea7&file=Fatal_error.7z
You do not have any valid material values defined. Right-click on the material in your model and chose "Edit". In the "Define Material" dialog box, either enter values for Young's Modulus & Poisson's Ratio or choose "Load" to populate with a material from a saved library. Then run your analysis and it should solve.
