Femap API Error "Type mismatch"
vvk_187
Student
Hi, Where is the mistake?
Code:
 pNodeSet.AddAll(zDataType.FT_NODE);
            pNodeSet.Debug();
            int nodeCount = pNodeSet.Count();
            Console.WriteLine("nodeCount =" + nodeCount);
            Console.ReadKey();
            int nodeID;
            object XYZ;
            object wpXYZ;
            double[] outwpXYZ = new double[3];
            while (pNodeSet.Next()>0)
                   nodeID = pNodeSet.CurrentID;
                   Console.WriteLine("nodeID =" + nodeID);
                   Console.ReadKey();
                     pNode.Get(nodeID);
                     XYZ = pNode.xyz;
                    pModel.feCoordToWorkplane(XYZ, out wpXYZ);
                    outwpXYZ = (double[])wpXYZ;
                  Console.WriteLine("nodeID=" + nodeID + " X=" + Math.Round(outwpXYZ[0], 2) + " Y=" + Math.Round(outwpXYZ[1], 2));
                  Console.ReadLine();
Solution
Thanks for the response.
This line gave an error
Fixed everything by adding an object variable to the loop before the function and zeroing it.
object wpXYZ=null;
The question can be considered closed
i'm not too versed in the C API, only femap's native BASIC and the python API, but what line is giving you the type mismatch?
also it seems this is not the full code, but an excerpt
object wpXYZ=null;
Solution
