Hi Guys
I'm unsure here about what torsional stiffness to use for a slab using RAM Concept. The options are:
1. Two-way slab - (KMrs is set to 100%, when I perform the analysis the results give 11.4mm longterm deflection).
2. No torsion two-way slab - (KMrs = 0.1%, longterm deflection = 25.4mm).
When I modify the KMrs manually, I get the following
3. KMrs = 10% ; longterm deflection = 20.8mm
4. KMrs= 25% ; longterm deflection = 18.4mm
5. KMrs= 50% ; longterm deflection = 15.6mm
Reading thru previus posts, RAPT suggests 30% (thread507-279687).
Is there an industry standard and has anyone had any real-life comparisions between FE and actual performance. This is a two-way reinforced member and there is nothing regular about it in terms of loading and support.
Any suggestions and further reading material will be appreciated.
