Hello.
I am in the middle of putting together several reports about fracture critical members and fatigue prone connections on welded truss bridges. All connections in the trusses themselves are welds, but some of the floor systems of them use a mix and match of welds and bolts. We have to identify E and E' welds (welds that are fatigue prone). I have looked at the Detail Categories for Load-Induced Fatigue (AASHTO Table 6.6.1.2.3-1), and I am having trouble with some of the various connections we encountered in the field in determining if they are considered E or E. welds. I have been all over the internet, and have had trouble finding guidance on examples of these welds. Is there any additional guidance out there I haven't found?
Currently, I have any transverse weld on or at the end of a tension member as an E or E' weld. Is any transverse weld on a tension member a fatigue prone connection? I have all of the tension connections on the gusset as fatigue welds. I can only find examples of tack welds and such on bolted gusset plate bridges. Any help would be greatly appreciated.
Thanks.
Thanks.
