Hello everybody,
i have to analyze an indentation test. So i implemented a contact problem between an elastic element and a plastic element.
I used the axisymmetric property, but i'm working on Femap 11.1 and I thought it would be fine.
Analysis reports two fatal erros:
Fatal Error 316(IFPDRV) and 9002 (IFPS).
316's window says :" ILLEGAL DATA ON BULK DATA ENTRY TABLED2
if you are using the large field format make sure the number of entries is even."
I know this error is usually the result of incorrectly defining a material or element property, but i checked.
could you please help me to solve these fatal errors?
Thanks and sorry for my english.
