Be careful about fastener choices... the configurations and materials and usage environments and torque settings and locking features, etc... all factor into fastening durability and 'harmony'.
Question to ask... not in any particular ranking/order...
Bolt/nut/washer configurations: what do these parts 'look like' by necessity. Example: hex-head bolts VS 2X-Hex VS Cap Bolts; plain, countersunk, split-lock, star-lock, etc washers; hex or 2X-hex or spanner or castellated etc Nuts... or tap-threaded holes with or without inserts and plain or self-locking, etc features.
Next Bolt, Nut and Washer alloys and corrosion protective finishes need to be considered. Carbon steel, Low alloy steel, stainless steels, heat resistant alloys, super alloys. Types of finishes such as zinc, zinc-nickel, cadmium, with extra chemical treatments such as chromates, phosphates, baked-on solid film lubricants, etc. Also installation lubricants for friction control: none, acetyl alcohol, lube-oil [often common to the vehicle systems], greases, CPCs [corrosion preventative compounds] or anti-seize ['wet' or dry/powdered [MoS2, graphite, etc]. Also Is the fastener install considered 'permanent' [no intention to remove], semi-permanent [remove for rare maintenance]; or an active maintenance remove/reinstall [such as wheels], etc.
CAUTION: Bolt, Washer and NUT alloys/strengths/finishes need to be in harmony with each other, IE: strength-durability-stiffness matching to prevent fastener failures due to 1-miss-matched part... and any materials miss-matches resulting in dissimilarities/corrosion or galling.
What is the environment: hot exposed to engine-oil, or coolant or other fluids, etc; hot-dry-dusty external; hot-humid-moist-salty external; salty-wet/slushy/snow/ice/rain; arctic external; exposed to exhaust/pollutants, etc. Is the fastener experiencing extreme thermal cycles or is it at long-term ambient?
How critical is assembly/re-assembly [long-term] torque-tension requirement? Configuration, alloys, finishes, surface damage, tools, etc all affect torque-tension. Friction increase usually translates to lower tension pre-load to a 'standard torque-value'... and yet increase shear stresses on head-fillets and threads; while reduced friction can result in excessive tension preload for the 'standard torque value' with increased tension load thru the head-filets and threads.
Now... does the fastener installation/assembly require 'locking' or is 'plain' OK. Self-locking parts are rarely re-useable after 10-15 assemblies. IF not self-locking, are they locked with a second/jam-nut, cotter-pins or lock-wire or thread-locking compound or external crimping, etc.
My head hurts and I have to go back to work.
Regards, Wil Taylor
o Trust - But Verify!
