Good Morning All,
Got a question for all of you. Why are all fasteners into treated lumber required to be galvanized or stainless besides the moisture aspect? Do the chemicals used to treat the lumber cause problems for standard nails/screws?
I've never had a need to know why I've just always specified hot-dipped galvanized or stainless nails and it's never been a problem until now. We have been retained to help certify some pwf foundations that were constructed incorrectly (yes foundations not a singular foundation, 8 duplexes). It hasn't been confirmed yet what kind of fasteners were used for the foundations but it appears as though common wire nails were used and then blue skin was applied over the nails.
If the fastener requirement is strictly because if you need treated lumber it is probably moisture susceptible or are there other factors in play?
