nasirqa1407
I have a huge mud pump that has a big crank shaft case cover that installed 35 angeld degree. Originally, this cover is attached by 22 studs. As it is hard to install the cover we change those studs to standard fastener bolts. With 6 month later, we observed that most of the fastener bolts are fractured from the head & body joint. I would suggest to reuse the old design attachment. Could you please advise me?
