R
robo_kk
Guest
I have a question concerning family table. I did two rings, steel one and a gasket. Next, I did an assembly. In this assembly there is one relation, telling that a radius of a gasket is a radius of a steel part minus its thickness. There is a family table of each part (concerning the different radius), and a family table made in assembly. In generic part I also used a "cut out" option, so that the outside part of the gasket is the same as an inside steel part. Unfortunately in instances this cut out option does not work.
Does anyone knows what is the problem?
I attach the problem I have if anyone would like to take a look
Problem with family table
Thanks!
Robert
Thanks!
Robert
