Family table
  • Thread starter Thread starter jackdog6
  • Start date Start date
J
jackdog6
Guest
I have a family table with 5 columns. All the columns are set at 2 decimals places (5.00). I would like to change the first column to only show one (5.0). When I change the first (cell) column, the remainig four columns also change. I would enter the note properties menu and change the value to 1. But the remaining seem to be locked. I also tried to change the value on the genric part (which worked) then updated the table with no change. Thanks for any help.
Have you changed the "Number of decimal places" for the desired dimension in the model?
Thanks James, yes I tried that but it seems to change all the columns. We just changed the table to 2D since we were in a hurry.
By the way, can I ask what company you work for? I work in the same field.
No way to change the display in the actual family table. You can change it in the report table though. Just as you would in a note.
