Chance17
Chemical
- Dec 2, 2005
- 256
Can the False Load control valve activate the suction drum safety valve when the compressor is running ?? I have seen numerous analysis saying control valve failure directly activates the suction drum PSV - he required flow being control valve "blow thru" rate. It appears to me to be a double contingency. i.e control valve failure & blocked suction drum outlet. What am I missing ??
FOR EXAMPLE: suction pressure = 40 psig
suction drum safety valve = 75-psig
compressor discharge = 100-psig.
false load control vave = fail open
