- others could perhaps provide background/source etc (in partial answer to your question, failure of e.g. a boiler with steam at 800 deg C would certainly not be pretty and that is probably stretching the limits - all study to avoid that with regard to materials should be done!)
Also be careful with engine exhaust through carbon steel pipe; if it gets too hot (i.e. someone comes along and insulates it) it can fail rapidly. Use stainless.
I am extremely sorry,
I messed up the units. Actually I meant 400 C (~800F).
@MJCronin,
Can you please explain why do "most piping codes limit carbon steel usage to a maximum continuous service temperature of about 775F (~412C)"?
What type of failure is observed at temperature higher than this?
The failure mode for continuous service at that temperature is spherodization/graphitization. In essence, the carbon comes out of solution with the iron and forms graphite flakes or spheres. This greatly weakens the steel and will lead to rapid, catastrophic failure without much warning.
