pcompg
Aerospace
- Feb 21, 2007
- 5
I've solved a composite structure in MSC Nastran with 4 plies below the meshed surface (PCOMP). On top of the meshed surface is honeycomb core modeled as solid elements and again 2 plies on top of core. Shell elements on top of core and below the core are in separate groups. The non-core region has 4+2=6 plies which are in a different group. I've set up Tsai-Wu failure theory. The failure indices extracted by "Failure indices, Maximum indices" and the maxumun of "Failure indices, Ply indices" do NOT match.
When I model a structure with constant number of plies throughout without the core, the failure indices extracted by the 2 methods match exactly.
Do you know the reason why failure indices do not match in the first case with core present.
