IronAgeGeorge
Computer
Hi, I hope I've come to the right place, I'm an archaeology researcher located in England with an engineering background and I've been asked to help a fellow researcher looking into possible reasons for failure of Bronze Age copper alloy artifacts such as axes.
It occurs to me this is a field in which we are in desperate need of some expert help.
One of the object types in question are small bronze wood cutting axes, some of these have failed by a fracture which runs in parallel with the cutting edge, 1-2cm back, either the entire cutting edge is lost or it "hangs off", with a large crack running at least 50% of the blade length.
Some of these axes also show signs of sometimes extreme mis-use and there is a train of thought which suggests these items may have been "ritually" broken.
However, I have a feeling that a great many of these objects hay have failed as a normal part of the product "life cycle". If I remember correctly, an axe, even when used completely normally will eventually fail due to small fractures joining up?
Ideally I'd like to find some failure analysis on similar objects, So something on failure of axes or hammers, and something on failure of copper alloys would be really good.
If anyone is interested I'd also like information on abnormal use failures, it occurs to me that in some cases what we are seeing is damage caused by continuing use after an initial failure. Or that the artifact was used "against the manufacturers instructions".
I hope someone can help, or at least point me in the right direction. Sorry I'm such a novice, I did three months of material science as part of my electronics based apprenticeship, that was a long time ago and the electronics swiftly moved on to computers.
