G
glue
Guest
Good Day!
I'm stuck with one problem I face, and as I am pretty new to ProE, I would gladly request some of your feedback and comments.
I am trying to create a protrusion which should represent the thickness (1mm) of a solid beam I have done before.
As you can see on the below sketch, this beam is made of a material x, which host a reinforcement tube along 35cm of the inboard edge (circular cut).
The feature highlighted in yellow is the part I am trying to extrude and which represent the thickness of the beam made from material y. Problem is that this thickness interfere with the wingskin as such I need to use the function "edge" in order to select the interference edges.
The extruded part should look like picture below:
However I get the following error message:
Would you have any idea why this protrusion fails?
As you might imagine I was trying to do the same protrusion on the right side of the beam, however there was other error message suggesting that the feature was open, hence could not be finalized...
Thanks in advance for your kind help!
Edited by: glue
Edited by: glue
