extrude solid/ surface
  • Thread starter Thread starter kenppy
  • Start date Start date
K
kenppy
Guest
The number of times that I hit extrude make the section and then realize that I didn't pick surface, then figure do I close this and start again or go back to sketcher and close the section then pick surface, then resketch....
Is there a config option that would make the default extrude section a surface by default.
Just asking.
You could set up a mapkey to start an extrude as a surface.
I believe that in wf1 , when you left the section open, it was automatically a surface.... but that option was later removed. Doesnt help you thoo...
Mapkey as mentioned above is a nice way.
//Tobias
Mapkey is the best way to figure out this problem.....
