Extrude Operation in NX8.5
spadazenon
GR
Dear All,
When I try to change the end limit of the extrude (double click the feature) from 10mm (Picture Scale1) to 15mm I get the result shown in Picture Scale2.
Does it happen only to me?
Thanx.
This (see attached) is what I get when I do this using NX 8.5.2.3. Kind of what I would expect and certainly not what it appears that you're getting.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
 http://files.engineering.com/getfile.aspx?folder=4a3528ac-cfe5-4041-bc6a-54eca09d267a&file=extrude_issue.zip
Dear cowski,
It works with the way you mention only if I deselect and re-select the sketch.
Dear John, I cannot open your video file, if you could please attach it again.
Thank you both for your replies.
I right click extrude 3, choose edit parameters and change the end distance to 15 and change the curve rule. It updates properly for me, with no need to deselect/reselect the sketch (NX 8.5.0.23). If I change the distance to 15 without also changing the curve rule, I get the same result you show.
www.nxjournaling.com
Here is the video file alone.
If you still can't play it, try this link:
Extrude Issue video.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
 http://files.engineering.com/getfile.aspx?folder=c02e46cf-37df-4886-abcb-cca8f508fee2&file=Extrude_Issue.avi
Dear John,
I can see that you have toggled the "Edit with Rollback" option instead of the "Edit Parameters" option. I use the "Edit Parameters" option cause is faster to load the feature.
When I change to that option I have the desired result but not if I have "Edit Parameters" option on (attached video).
Dear cowski,
I did it again, but it doesn't work for me. NX8.5.2.3 (attached video)
Is this happening to me only?
Thank you again.
 http://files.engineering.com/getfile.aspx?folder=bbfe404a-737c-4211-a922-667f4c15f7fc&file=extrude_issue_2.zip
OK, I see what you're seeing but have no explanation. It appears to be a bug. I'm going to open a PR and see what I can learn,
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Oops, I misspoke.
I did change the curve rule and distance value separately. My method did require a deselect/reselect. When I perform the edit exactly as you describe, I get the same result.
My apologies.
I went back and created a similar part in NX 7.5 and it worked fine, irrespective as to how I edited the model, therefore this is a regression. And if I open that NX 7.5 part file in NX 8.5 I now see the inconsistent behavior, which I did NOT see in NX 7.5. I will keep you posted of what I learn.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
