Extrude Direction
TheRealDeal55
Automotive
Jun 1, 2012
25
I am using NX 8.5. When I create a sketch and attempt to extrude it does
not default normal to sketch plane. Is there a setting that controls
extrude direction? As of now I need to define extrude direction every time.
Thanks in advance.
I am unaware of any setting which will control this behavior. I've tested NX 8.5 and no matter what orientation I define my sketch in, as soon as I select even a single curve of the Sketch, the system defaults to extruding it normal to the plane of the Sketch. May I suggest that the next time that you open the Extrude dialog that you select the 'Reset' button in the upper-Right corner of the dialog and see if that corrects this behavior.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
