Extracting Points for Standard Deviation
JPM73
I have a bunch of points on a surface. How can I validate that these points are on the surface or some distance off of it, then calculate the standard deviation.
QuEST / GE Mechanical Designer
you can use Analysis |Deviation|Gauge,checking to validate it.It'll helpfull.
This is in refererenc to my orginal, "Extracting Points for Standard Deviation" posting.
I uploaded a MS Word file with a handful of pics to better explain on what I'm trying to accomplish.
As you should see from the pictures, there's a handful points that should be along the face of the profile that it outlines.
I'm trying to determine if each of these points are actualy on the face & if the are not, what distance does it deviate from it.
With collected data, I will probably calculate the standard deviation.
Please suggest methods to produce accurate results.
 http://files.engineering.com/getfile.aspx?folder=4cdb9a2f-76ba-4add-b650-501ddd46ca5c&file=t_pollarha-0000-p5094_pics.doc
