Now that I have recieved/reviewed the measured data, the situation is quite a bit worse than I had anticipated.
George, previously I have correlated against measured strains at discrete frequencies. I used an optimization routine because I was varying the modal damping in addition to addjusting the load input. Using influence coefficents as you described is a good idea. Also, the load path was well defined in my previous applications.
In the current problem, the response is broadband even though the load is applied at ~18 Hz. The load appears to be shock type (gun firing), so it is exicting the structure between 180 to 400 Hz. Also, several of the strain gauges are responding like a damped, single-dof-system. However, they are responding at different frequencies (167, 250, 310, 400) which are not all multiples of 18 Hz.
Things that I have done
a) Did cycle count and applied miner's rule to the measured strain. Strains are below the level that causes fatigue damage, so part has infinte life.
a) Calculated frequency response (doesn't help too much, shows the response is broadband)
b) Calculated coherence between gauges (may help, clearly identifies where the frequency ranges where the gauges have high coherence. Possibly this implies structural modes.
c) Used the nastran model to calculate mode shapes up to 400 Hz (37 modes). Divided the maximum stress in the mode shape by the stress at the gauge location, and plotted vs frequency. The values depend on the gauge, but the averages range from about 30 to 120.
d) Showed that a modal amplification factor (Maximum stress divided by gauge stress for a NASTRAN mode) of 10 results in an unacceptable fatigue life.
e) Fitted a single dof equation,
d2x/dt2+2*zeta*wn*dx/dt+wn^2*x = g(t), and calculated damping, natural frequency, and g(t) for one of the gauges.
Things I would like to do
a) 3 of the strain gauges are on primary load paths, but not in the direction of the primary load. Also, there is a 4th primary load path that is not gauged, and numerous secondary load paths. Use the 3 primary loads as inputs, and the large response strain gauges as outputs, and a routine like N4SID to calculate the linear function relating the inputs/output/states. If the predicted response matches the measured response, determine how much of the response is due to input vs natural frequencies.
b) Use coherence between the gauges to identify the strain mode shape. Compare back to NASTRAN modes to (hopefully) identify which modes are responding at that high frequency.
c) In NASTRAN, modify the frequencies of the modes from step b (I've done this before) to the estimated value from data. Apply shock time history loads to NASTRAN. Optimize the shape of the shock time history, and the modal damping to generate the measured strains.
Unresolved problems are
a) On the one hand, the simple cycle count/miner's rule shows large life. On the other hand, the response has clear, damped, cyclic response. Estimates of the maximum stress indicates that the part would have a very short life.
b) Currently, the data supports the hypothesis that structural modes are being excited. How to prove this definatively. An alternate explanation is that the load support structure modes are being excited, and the primary structure is just responding to inertia forcing.
c) Currently, the NASTRAN estimation of the amplification factors are quite a bit higher than allowed, resulting in a high oscillatory stress and a very low fatigue life. The system has been in field use for a few months, and there hasn't been a fatigue failure.
