BSPE90
- Aug 30, 2017
- 22
The projects I typically work on are in warm climates where frost depth is not too much of an issue (my company generally thickens the concrete mat down to frost depth). We have a project now in New England and frost depth is apparently 4-5 ft up there.
What is typically done to design an economical outdoor equipment pad?
One solution I have heard is that you can remove the soil below the pad down to frost depth and replace with large granular fill. But one engineer has a concern that it can fill up with water and freeze which would still cause heaving issues.
