Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
;*** TEXTOUT.LSP
;*** Written by Don J. Buschert (c) 1996
; Email: don.buschert@sait.ab.ca
; buschert@spots.ab.ca
; AutoCAD Page: [URL unfurl="true"]http://www.spots.ab.ca/~buschert/autocad/main.htm[/URL]
; Disclaimer:
; Permission to use, copy, modify, and distribute this software
; for any purpose and without fee is hereby granted, provided
; that the above copyright notice appears in all copies and
; that both that copyright notice and the limited warranty and
; restricted rights notice below appear in all supporting
; documentation.
; THIS PROGRAM IS PROVIDED "AS IS" AND WITH ALL FAULTS. THE AUTHOR
; SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF MERCHANTABILITY OR
; FITNESS FOR A PARTICULAR USE. THE AUTHOR ALSO DOES NOT WARRANT THAT
; THE OPERATION OF THE PROGRAM WILL BE UNINTERRUPTED OR ERROR FREE.
; Version 1.1 06/20/97
; Revised the (REMOVE_ELEM) function thanks to Reini Urban pointing out a
; serious flaw in the original by C. Bertha. Apparently if there were multiple
; elements, the old version would add the element instead of removing it.
; Version 1.0 May 15, 1995
; Original program.
; Outputs selected text to an ASCII file. Sorts the text by the
; Y value, so you can select by window or crossing, and the lines
; in the ASCII file will be correct. You must select text with a
; rotation angle of 0. Failing to do so may yield unpredictable
; results.
; Warning! There is a bug in the program. If you select text objects with y
; values that are equal, TX2MTX will ignore them entirely. Just be aware of
; the text objects your are selecting. I'll get around to fixing this
; eventually...
(princ "\nInitial load, please wait...")
;*** Function TEXTOUT_SORT
;This functions sorts the text object selection set and returns it
;in order with the highest Y values at the beginning...
(defun TEXTOUT_SORT ( / )
;create dotted pair list of text Y insertions points and string
(setq tout_indx 0);set the index
(repeat (sslength tout_sst2);repeat for each text object
(setq tout_enam (ssname tout_sst2 tout_indx));get object name
(setq tout_strg (cdr (assoc '1 (entget tout_enam))));get string
(setq tout_yval (caddr (assoc '10 (entget tout_enam))));get y value
(setq tout_dtpr (cons tout_yval tout_strg));create dotted pair
(if tout_dtpr_list ;if dotted pair list exists,
(setq tout_dtpr_list (cons tout_dtpr tout_dtpr_list));then append
(setq tout_dtpr_list (list tout_dtpr));else create it
;increase index
(setq tout_indx (1+ tout_indx));set the index
;create list of y values
(foreach n tout_dtpr_list ;for each item in the dotted pair list...
(setq tout_yval (car n));get the y value
(if tout_yval_list ;if the y value list exists,
(setq tout_yval_list (cons tout_yval tout_yval_list));add
(setq tout_yval_list (list tout_yval));else create
;sort the y value list
(while (> (length tout_yval_list) 1);as long as more than 1 element...
(setq tout_yval (apply 'MIN tout_yval_list));get the min Y value
(if tout_yval_slis ;if the Y value sorted list exists,
(setq tout_yval_slis (cons tout_yval tout_yval_slis));add
(setq tout_yval_slis (list tout_yval));else create
;remove the y value from the y value list
(setq tout_yval_list (remove_elem tout_yval tout_yval_list))
;add the last element to the sorted y value list
(setq tout_yval_slis (cons (car tout_yval_list) tout_yval_slis));add
(setq tout_yval_slis (list (car tout_yval_list)));else create
;create a string list of the text values based on the sorted Y value
;list
(foreach n tout_yval_slis ;for each element in the sorted Y value list...
(setq tout_text (cdr (assoc n tout_dtpr_list)));get the text string
;if text string list exists
(if tout_text_list
(setq tout_text_list (cons tout_text tout_text_list));add to list
(setq tout_text_list (list tout_text));else create it.
;reverse the order of the text list
(setq tout_text_list (reverse tout_text_list))
;Controls and executes program
(defun C:TEXTOUT ( /
tout_coun ;counter
tout_filo ;open'ed file
tout_flag ;flag.
tout_fnam ;ASCII file name
tout_dtpr ;dotted pair
tout_dtpr_list ;dotted pair list
tout_enam ;entity name
tout_indx ;index
tout_sst1 ;initial selection set
tout_sst2 ;text only selection set
tout_strg ;string
tout_text ;text string
tout_text_list ;text string list
tout_yval ;text Y value
tout_yval_list ;Y value list
tout_yval_slis ;Sorted Y value list
;Define error routine for this command
(defun textout_error (s)
(if (/= s "Function cancelled.");if ^c occurs...
(princ (strcat "\nError: " s))
(if olderr (setq *error* olderr))
(princ)
(setq olderr *error*)
(setq *error* textout_error)
;select text
(setq tout_sst1 (ssget))
;if objects selected...
(if tout_sst1
(progn
;create list of text objects only
(setq tout_coun 0);set counter
(setq tout_sst2 (ssadd))
(repeat (sslength tout_sst1)
;get ename
(setq tout_enam (ssname tout_sst1 tout_coun))
;test to see if entity is a text object
(if (eq (cdr (assoc '0 (entget tout_enam))) "TEXT")
;check to see if text has rotation angle of 0
(if (<= (cdr (assoc '50 (entget tout_enam))) 1.0)
(setq tout_sst2 (ssadd tout_enam tout_sst2));add to selection
(setq tout_coun (1+ tout_coun))
(if tout_sst2
(princ
(strcat "\n" (itoa (sslength tout_sst2))
" text objects found, with horizontal rotation..."
;if tout_sst2 is empty, then clear it...
(if (eq (sslength tout_sst2) 0)
(setq tout_sst2 nil)
;if there were text objects selected, then
;get a name for the ascii file
(if tout_sst2
(setq tout_fnam (getfiled "TEXTOUT - ASCII Filename" "" "txt" 1))
;if a filename was selected
(if tout_fnam
(progn
;sort the selected text objects by Y value...
(TEXTOUT_SORT)
;open the file for writing
(setq tout_filo (open tout_fnam "w"))
;for each selected text object, write to the file
(if tout_text_list
(foreach n tout_text_list
(write-line n tout_filo)
;close the file
(close tout_filo )
;delete the seleted text
(if (not tout_flag)(setq tout_flag "Yes" ))
(initget "No Yes" )
(setq tout_flag
(getkword (strcat "\nErase selected text? Y/N <" tout_flag ">: "))
(if (not tout_flag)
(setq tout_flag "Yes")
(if (eq tout_flag "Yes")
(command ".ERASE" tout_sst2 "")
(princ)
;Support functions
;*** REMOVE_ELEM
;This function removes an element from a list and return the list without
;the element. This program was originally known as serge:remove, written
;by Serge Volkov, the winner of the great lisp puzzle contest in
;comp.cad.autocad 11.Oct.96. Reini Urban calls it "elegant and fast".
(defun REMOVE_ELEM (what from)
(apply 'append (subst nil (list what) (mapcar 'list from)))
(princ)
