I have to provide a STEP file of an assembly, but with the components exploded.
I figured I'd do it in the Explode/Render/Animate environment... But when I try to save the exploded configuration as STEP, SE tells me "The model contains no bodies. An output file will not be generated".
I would have prefered not to change the assembly constraints, but it looks like it's the only possible way to do this... Unless anyone has a better idea?
Thanks.
Thanks.
