I want to export a NX drawing to DWG file in Scale 1:1?
Example: if Views are created in NX with Scale 1:5 then if I measure in AutoCAD the measurement is 5 times smaller than it should be.
While exporting there is an option in the DXF/DWG wizard which is OUTPUT AS "LAYOUT". But in my instance i first use 2D Xchange to create a 2D part and then i use this 2D part for DWG translation.This option is not available for a 2D part.
Is there any other solution to my problem?
Thanks,
Thanks,
