Export STEP journal
niedzviedz
PL
Hello everyone,
I have created journal to export step203 from selected bodies, but I receive error:
*** ERROR ***
3600002 : Symbol not found in library
The same journal, but used step214creator work perfect. What I'm doing wrong?
Below Is my code.
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports Microsoft.VisualBasic
Module NXJournal
    Sub Main()
       Dim theSession As Session = Session.GetSession()
       Dim ufs As UFSession = UFSession.GetUFSession()
       Dim workPart As Part = theSession.Parts.Work
       Dim displayPart As Part = theSession.Parts.Display
       Dim lw As ListingWindow = theSession.ListingWindow
       Dim mySelectedObjects() As NXObject
       Dim myResponse As Selection.Response
       Dim tagList() As NXOpen.Tag
       Dim exportFileName As String = Nothing
       Dim exportFileName1 As String = Nothing
       Dim nazwa as string
       Dim path As String
       Dim step203File As String
       Dim STEP203UG_DIR As String = theSession.GetEnvironmentVariableValue("STEP203UG_DIR")
       step203File = IO.Path.Combine(STEP203UG_DIR, "ugstep203.def")
	lw.Open()
        If Not IO.File.Exists(step203File) Then
            MsgBox("The step203 settings file (ugstep203.def) was not found." & vbCrLf & _
                "This journal will now exit.", vbOKOnly + vbCritical)
            Exit Sub
        Else
 		'lw.WriteLine("STEP203 definition file found at: " & step203File)
        End If
       Dim i As Integer = 0
       myResponse = SelectObjects(mySelectedObjects)
       If (myResponse = Selection.Response.Cancel) OrElse (myResponse = Selection.Response.Back) Then
           'user canceled selection, exit journal
           Exit Sub
       End If
       ReDim tagList(mySelectedObjects.GetUpperBound(0))
       For i = 0 To mySelectedObjects.GetUpperBound(0)
           tagList(i) = mySelectedObjects(i).Tag
       Next
       'return the full path of the work part
       exportFileName = workPart.FullPath
       nazwa = workPart.Leaf
       path = IO.Path.Combine(IO.Path.GetDirectoryName(workPart.FullPath), "step")
	If(Not System.IO.Directory.Exists(Path)) Then
    		System.IO.Directory.CreateDirectory(Path)
	End If
	exportFileName = IO.Path.Combine(path, nazwa & ".stp")
       'if this file already exists, delete it
       If My.Computer.FileSystem.FileExists(exportFileName) Then
           My.Computer.FileSystem.DeleteFile(exportFileName)
       End If
        Dim numUnexported As Integer
       Try
      ' ufs.Ps.ExportLinkedData(Taglist, Taglist.Length, exportFileName, PSversion, Nothing, numUnexported,
Nothing)
        Dim step203Creator1 As Step203Creator
        step203Creator1 = theSession.DexManager.CreateStep203Creator()
        step203Creator1.SettingsFile = step203File
        step203Creator1.ObjectTypes.Solids = True
        step203Creator1.LayerMask = "1-256"
        step203Creator1.InputFile = workPart.FullPath
        step203Creator1.OutputFile = exportfilename
        step203Creator1.FileSaveFlag = False
	step203Creator1.BsplineTol = 0.0001
	Step203Creator1.ColorAndLayers = 1
        step203Creator1.ExportSelectionBlock.SelectionScope = ObjectSelector.Scope.SelectedObjects
        Dim nXObject1 As NXObject
        nXObject1 = step203Creator1.Commit()
        step203Creator1.Destroy()
        lw.Close()
       Catch ex As NXException
           lw.WriteLine("*** ERROR ***")
           lw.WriteLine(ex.ErrorCode.ToString & " : " & ex.Message)
       End Try
       lw.Close()
    End Sub
   Function SelectObjects(ByRef selobj() As NXObject) As Selection.Response
       Dim theUI As UI = UI.GetUI
       Dim prompt as String = "Select Solid Bodies"
       Dim title As String = "Selection"
       Dim includeFeatures As Boolean = False
       Dim keepHighlighted As Boolean = False
       Dim selAction As Selection.SelectionAction = _
           Selection.SelectionAction.ClearAndEnableSpecific
       Dim scope As Selection.SelectionScope = _
           Selection.SelectionScope.AnyInAssembly
       Dim selectionMask_array(0) As Selection.MaskTriple
       With selectionMask_array(0)
           .Type = UFConstants.UF_solid_type
           .Subtype = 0
           .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_SOLID_BODY
       End With
       Dim resp As Selection.Response = _
           theUI.SelectionManager.SelectObjects( _
           prompt, title, scope, selAction, _
            includeFeatures, keepHighlighted, _
            selectionMask_array, selobj)
       Return resp
   End Function
End Module
With best regards
Michael
Hello Cowski, It doesn't display number of line. I think that the error is from listing window.
With best regards
Michael
I'm not asking for the line of code that throws the error (which is a bit unusual for me [glasses]). Rather, I'm asking you which line of code do you think tells the step203 exporter object to use the objects that you are interested in?
www.nxjournaling.com
This line:
Code:
With best regards
Michael
One more thing - I closed NX and after restart I tried one more time and it's start working. Then I tried step214 and I receive the same error like in post 1. So the problem is with NX.
With best regards
Michael
That line simply tells it to use the "selected objects" option rather than the "entire part" option. It does NOT tell the exporter object which objects in particular that you are going to export.
In other words, that option sets the scope of what is going to be exported. It is analogous to changing the export option in the GUI to "selected objects"; your next step in the GUI version is to select object(s) to tell it what to export. Now that you have set the scope, you need to use the .ExportSelectionBlock.SelectionComp.Add() method to pass it the solids that you selected previously.
There is function to select bodies:
Code:
           .Subtype = 0
       End With
       Return resp
   End Function
With best regards
Michael
Ok, below is my latest code:
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module NXJournal
    Sub Main()
       Dim nazwa as string
       Dim path As String
	lw.Open()
            Exit Sub
        Else
        End If
           Exit Sub
       End If
       Next
	End If
       End If
       Try
        Dim added1 As Boolean
        added1 = step203Creator1.ExportSelectionBlock.SelectionComp.Add(mySelectedObjects.ToArray)
        lw.Close()
       End Try
       lw.Close()
    End Sub
           .Subtype = 0
       End With
       Return resp
   End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        Return Session.LibraryUnloadOption.Immediately
    End Function
End Module
I added this
Code:
And I've got an error: "Element "ToArray" is not a member of element "system.array" ".
Any suggestions?
With best regards
Michael
The [tt]mySelectedObjects[/tt] variable is already an array; there is no need to try to convert it to an array.
Code:
added1 = step203Creator1.ExportSelectionBlock.SelectionComp.Add(mySelectedObjects)
Thanks Cowski, now it's working. What I'm gonna do is create journal to process whole assembly and for each part create step file. Below is my journal, byt I have problem with SelectionScope.
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Assemblies
Imports System.Collections.Generic
Module NXJournal
    Public theSession As Session = Session.GetSession()
    Public ufs As UFSession = UFSession.GetUFSession()
    Public lw As ListingWindow = theSession.ListingWindow
    Dim filename as string
    Dim poz as string
    Sub Main()
    Dim dispPart As Part = theSession.Parts.Display
    lw.Open
    Try
        Dim c As ComponentAssembly = dispPart.ComponentAssembly
	if not IsNothing(c.RootComponent) then
            ReportComponentChildren(c.RootComponent, 0)
        else
            lw.WriteLine("Part has no components")
        end if
    Catch e As Exception
        theSession.ListingWindow.WriteLine("Failed: " & e.ToString)
    End Try
    lw.Close
    End Sub
    Sub reportComponentChildren( ByVal comp As Component, _
        ByVal indent As Integer)
       Dim nazwa as string
       Dim path As String
       Dim PSversion as integer = 240
       Dim layerNumber as Integer = 1
       Dim theBodies As New List(Of Body)
       Dim theBodyTags as New List(Of Tag)
       Dim step214File As String
       Dim STEP214UG_DIR As String = theSession.GetEnvironmentVariableValue("STEP214UG_DIR")
       step214File = IO.Path.Combine(STEP214UG_DIR, "ugstep214.def")
       lw.open
	If Not IO.File.Exists(step214File) Then
            MsgBox("The step214 settings file (ugstep214.def) was not found." & vbCrLf & _
            Exit Sub
        Else
 		'lw.WriteLine("STEP214 definition file found at: " & step214File)
        End If
        For Each child As Component In comp.GetChildren()
             If LoadComponent(child) Then
		Dim MyPart As Part = child.Prototype.OwningPart
	        filename = child.DisplayName()
			'Msgbox(filename)
	lw.open
	theBodyTags.clear()
	For each tempBody as Body in mypart.Bodies
 	  if tempBody.Layer = 1 then
 	       theBodies.Add(tempBody)
	   end if
	Next
'	lw.WriteLine("number of bodies found: " & theBodyTags.Count.ToString)
	if theBodyTags.Count = 0 then
	    lw.writeline("no bodies to export")
	    return
	end if
	exportFileName = myPart.FullPath
        nazwa = myPart.Leaf
       path = IO.Path.Combine(IO.Path.GetDirectoryName(myPart.FullPath), "step")
	End If
       End If
       Try
        Dim step214Creator1 As Step214Creator
        step214Creator1 = theSession.DexManager.CreateStep214Creator()
        step214Creator1.SettingsFile = step214File
        step214Creator1.ObjectTypes.Solids = True
        step214Creator1.LayerMask = "1"
        step214Creator1.InputFile = myPart.FullPath
        step214Creator1.OutputFile = exportfilename
        step214Creator1.FileSaveFlag = False
        step214Creator1.ExportSelectionBlock.SelectionScope = ObjectSelector.Scope.thebodies
        added1 = step214Creator1.ExportSelectionBlock.SelectionComp.Add(thebodies)
        nXObject1 = step214Creator1.Commit()
        step214Creator1.Destroy()
        lw.Close()
       End Try
       lw.Close()
		end if
  	' end if
         '   Else
                'component could not be loaded
       '     End If
            reportComponentChildren(child, indent + 1)
        Next
    End Sub
    Private Function LoadComponent(ByVal theComponent As Component) As Boolean
        Dim thePart As Part = theComponent.Prototype.OwningPart
        Dim partName As String = ""
        Dim refsetName As String = ""
        Dim instanceName As String = ""
        Dim origin(2) As Double
        Dim csysMatrix(8) As Double
        Dim transform(3, 3) As Double
        Try
            If thePart.IsFullyLoaded Then
                'component is fully loaded
            Else
                'component is partially loaded
            End If
            Return True
        Catch ex As NullReferenceException
            'component is not loaded
            Try
                ufs.Assem.AskComponentData(theComponent.Tag, partName, refsetName, instanceName, origin,
csysMatrix, transform)
                Dim theLoadStatus As PartLoadStatus
                theSession.Parts.Open(partName, theLoadStatus)
                If theLoadStatus.NumberUnloadedParts > 0 Then
                    Dim allReadOnly As Boolean = True
                    For i As Integer = 0 To theLoadStatus.NumberUnloadedParts - 1
                        If theLoadStatus.GetStatus(i) = 641058 Then
                            'read-only warning, file loaded ok
                        Else
                            '641044: file not found
                            lw.WriteLine("file not found")
                            allReadOnly = False
                        End If
                    Next
                    If allReadOnly Then
                        Return True
                    Else
                        'warnings other than read-only...
                        Return False
                    End If
                Else
                    Return True
                End If
            Catch ex2 As NXException
                lw.WriteLine("error: " & ex2.Message)
                Return False
            End Try
            'unexpected error
            lw.WriteLine("error: " & ex.Message)
            Return False
        End Try
    End Function
    End Function
End Module
I get an error "Element "thebodies" is not member of "NXopen.ObjectSelector.scope".
When I used function selectobject, the journal works, but in each exported stp file I have solid bodies from each files. So I try similar method which I used in "export parasolid" journal some time ago.
With best regards
Michael
For the selection scope, use [tt].SelectedObjects[/tt]. In this code, the variable theBodies is declared as a list object; this time you will have to convert it to an array.
Code:
step214Creator1.ExportSelectionBlock.SelectionScope = ObjectSelector.Scope.[highlight #FCE94F]SelectedObjects[/highlight]
added1 = step214Creator1.ExportSelectionBlock.SelectionComp.Add(theBodies[highlight #FCE94F].ToArray[/highlight])
Thanks Cowski You are The best. Below is my final code, maybe it will be useful for someone in the future.
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module NXJournal
    Dim poz as string
    Sub Main()
    lw.Open
    Try
        else
        end if
    End Try
    lw.Close
    End Sub
       Dim nazwa as string
       Dim path As String
       lw.open
            Exit Sub
        Else
        End If
			'Msgbox(filename)
	lw.open
	theBodies.clear()
	   end if
	Next
'	lw.WriteLine("number of bodies found: " & theBodies.Count.ToString)
	if theBodies.Count = 0 then
	    lw.writeline("no bodies to export in " & mypart.fullpath)
	    'return
	end if
        nazwa = myPart.Leaf
	End If
       End If
       Try
	'step214Creator1.ExportSelectionBlock.SelectionComp.clear
	step214Creator1.BsplineTol = 0.0001
        step214Creator1.ExportSelectionBlock.SelectionScope = ObjectSelector.Scope.SelectedObjects
	added1 = step214Creator1.ExportSelectionBlock.SelectionComp.add(thebodies.toarray)
        lw.Close()
       End Try
       lw.Close()
		end if
  	' end if
         '   Else
       '     End If
        Next
    End Sub
        Try
            Else
            End If
            Return True
            Try
                        Else
                            allReadOnly = False
                        End If
                    Next
                    If allReadOnly Then
                        Return True
                    Else
                        Return False
                    End If
                Else
                    Return True
                End If
                Return False
            End Try
            'unexpected error
            Return False
        End Try
    End Function
    End Function
End Module
I have one more question - how can I create a folder and place stp files in there, but this folder will be 1 level up.
Here is my theoretical structure:
Code:
 <Project number>
[indent]<2D>[/indent]
[indent]<3D>[/indent]
[indent][indent]NX parts[/indent][/indent]
[indent]<STEP>[/indent]
The folder I wanna create is <STEP>.
With best regards
Michael
Thanks again, I will try it tomorrow.
With best regards
Michael
