Do someone can show me a good internet site where it is possibe to get a detailed and comprehensive CHECK LIST to be follwed during the DESIGN & CONSTRUCTION of a Pressure Vessel?
We get an order for a Pressure VEssel for China Market, but we do not know the GB-150 and we do not know if the simple use of ASME VIII1- or VII-2 is enough to get the approval from the China Authorities.
Exampe: if the requirements stated in the following Par. of ASME VIII-1 are accepted withount any problems or if there are other additional constraints to be followed:
Materials that can be used to Manufacture a Pressure
Vessel (Ex.: UCS-5 to UCS-12,UNF-5 to UNF-15 and
UHA-11 to UHA-13) + any constraints on teh Raw Material
Procurament.
UG-23 + UCS-23 + UNF-23 + UHA-23
(Which Allowable Stresses to use to Design a Vessel)
UW-11 to UW-20 + UCS-19 + UNF-19 + UHA-21
(Regarding the Joint Efficencies to be used in conjunction
with the Inspection Level Phylosophy [ Ex.: RT-1 to RT4 or
NO RX Check ]and which Weld Joint Details are allowed
or not allowed)
UG-16
(Minimum Thickness of Pressure Retaining Components)
UG-11 + UG-44 + UW-21 for Standard Flanges
(Use of the Standard Rating without performing
any other additional Code Calc.)
UG-84 + UCS-66/67/68 + UNF-56 + UHA51
(For Impact Tests Requirements)
UW-10 + UW-40 + UCS-56 + UNF-56 + UHA-32
(For PWHT Requirements)
UG-99 or UG-100
(Final Equipment Testing)
Any other ASME Par. tied to the FABRICATION and INSPECTION
activities to be performed on teh Vessel during the DESIGN
and MANUFACTURING.
Many thanks in advance.
Procurament.
or not allowed)
UG-16
UG-99 or UG-100
and MANUFACTURING.
