I need to export calculated values to a file, which name will be created automaticly based on values of three scalar parameters.
I need format of writting as in attached "file1.txt" I can create this file when click on properities and write the name of the file directly - I can not write the name in parametric way.
I try to use the WRITEPRN command and it worked, but the format of written values is different as in attached "file2.txt".
After two hours spent in mathcad help I gave up. So can someone advise how to write a file with parametric name and which have the format as in file1.txt, please ? Thank you !
Lubo
Lubo
