I HAVE BEEN REQUESTED TO INSPECT AND "CERTIFY" AN EXISTING 8 INCH BLOCK FOUNDATION/FOOTING (ASSUMED TO BE HOLLOW CORE, NONGROUTED, AND WITHOUT ANY REBAR OR REINFORCING) OF A RAISED RANCH HOUSE (35 YEARS OLD)THAT HAS HAD FIRE DAMAGE. THE HOUSE IS LOCATED IN THE NORTHEAST. THE OWNER ANTICIPATES TEARING DOWN THE EXISTING FRAMING TO THE BLOCK AND REPLACING IT WITH A MODULAR OF SIMILAR DESIGN. AN INITIAL REVIEW INDICATES THAT THE HOUSE LOADINGS WILL BE SIMILAR. THE QUESTION IS IN REVIEW OF THE FOUNDATION. THERE IS NO PHYSICAL DAMAGE TO THE BLOCK FOUNDATION FROM THE FIRE AND THE IT IS GENERALLY IN GOOD CONDITION,ONLY A FEW RANDOM HAIRLINE CRACK ARE VISUALLY EVIDENT. THERE IS VISUALLLY NO EVIDENCE OF DAMAGE TO THE FOUNDATION FROM HEAVING, WATER DAMAGE OR AFFECTS OF AN UNBALANCED BACKFILLL LOADING. WOULD THE INTENSITY OF THE FIRE (ON THE TOP FLOOR) HAVE CAUSED DAMAGE TO THE BLOCK STRENGTH THAT I MAY NOT BE AWARE OF. ALSO, THE CONCRETE FOOTING (ASSUMED TO CONTAIN NO REINF.)WAS UNCOVERED AND IT VISUALLY APPEARS TO BE IN BETTER THAN GOOD CONDITION, HAVING UNDERDRAIN ADJACENT TO IT. THE EXTERIOR FOOTING WIDTH VISIBLE IS 5 INCHES AND I ASSUME (??) THE SAME OFFSET WIDTH ON THE INTERIOR, WITH A MEASURED DEPTH OF 7 +/- INCHES. I AM CONCERNED WITH THE INTEGRETY OF THE CONCRETE FOOTING. THE EXTERIOR SURFACE (APPROX 1/8 INCH IN DEPTH) APPEARS SOFT AND EASILY SCRAPED OFF. IS THERE A METHOD OF EVALUATING THE SOUNDNESS OF THE CONCRETE FOOTING WITHOUT DESTROYING IT? THANKS FOR ANY HELP ON THIS ISSUE.
