We had a call from a homeowner re: excessive internal water pressure (150psi). We tested a local hydrant outside the house and found that while the water pressure at the hydrant remained constant for two days(95psi), the taps in the house experienced spikes ranging from 95psi to 150psi, every few hours. The house used to be connected to a well, but it doesn't appear to be still in service. Is it possible that the old well pump is providing the spikes, or is there another reason that the spikes are occuring?
