Excell/API/Macro/Conversion
krywarick6
Automotive
CA
I'm writing a macro within Excel. When I transfer a cell value into a SolidWorks model dimension I divide the cell value by 1000 to get a millimeter value for the model, as in the following example:
Part.Parameter("Dim@Sketch@Model.SLDPRT").SystemValue = [cell].Value / 1000
This works fine for linear dimensions.
Problem: I want to transfer an angular value. I can't seem to figure out what the relationship is during the transfer. For instance, when I want to transfer the value of 36°, it transforms into 2063°.
Does anyone have a suggestion for a conversion factor? It doesn't appear to even be a radian value, ie. 36/360*2pi = .628pi. The closest that I can get is (36/1000) * (36/2), but this yields 37°+.
I'm totally baffled.
Christopher Zona
Litens Automotive Partnership
Concord, Ontario, Canada
Actually it is a Radian value.
1 Radian = 360/2pi = 360/2/pi = 57.29577951°
So your angular cell conversion should be Value/(360/(2pi))
Proof:- 2063/57.29577951 = 36.00614247
Note; the 2063° figure you quote, must have been rounded off.
[cheers] from (the City of) Barrie, Ontario.
[smile] Support bacteria - they're the only culture some people have [smile]
Great! Worked like a charm. The question now is how to do I put pi into my code?
I tried using pi() as you would type it into a cell formula but the macro doesn't like that.
For now I am using 3.14159, which close enough. It returns 35.99996959deg, but I am a bit of a perfectionist and would like to see 36.
Any ideas?
Z
Sorry to waste your time. I figured it out.
Const pi As Double = 3.14159265358979
Z
Could you put pi() into another cell & reference it to the cell which is used in the macro?
Or use 3.14159265358979..........
Perhaps you could do the calculating in Excel. Excel has functions for converting radians to degrees and vice-versa. Excel also has a function for [π].
Maybe it would help to buffer the data transfer. Pass the Excel cell values to a variable, then pass the variable value to the SolidWorks entity.
[bat]Due to illness, the part of The Tick will be played by... The Tick.[bat]
Most common VBA 'pi function': 4.0*ATN(1.0)
