Excel Worksheets.Add
rnordquest
New member
These used to work just fine but now I get an error:
Set Summary = Worksheets.Add
Summary.Name = "Summary"
Set NewSheet = Worksheets.Add
NewSheet.Name = "Spec_Summary"
I get:
Run-time error'1004'
Method 'Add' of object 'Sheets" failed
Any ideas on what caused this or what I can do to fix it?
Thanks,
Roger
Have you upgraded to a different version of Excel? I often find errors like this after upgrading because Microsoft changes little things.
Not that I know of. I'll have to check. We're supposed to move to Office 2003 but that hasn't happened yet.
Has Excel possibly been recently re-installed? Each time a machine is "re-imaged" (or a new machine is installed) at work, we have to install a couple of the add-ins to get some of our regularly-used functions to work (such as "EDATE" in the Analysis ToolPak).
Looking at the ToolPaks available here, a couple have appear to be VBA related, i.e. Analysis ToolPak - VBA.
The above probably doesn't apply, but might be worth pursuing.
-InspEngr
Have you tried manually adding a worksheet (Insert/Worksheet in Excel)? Maybe the workbook is protected, or something similar.
Cheers,
Joerd
joerd,
You are right as always. I can't insert a worksheet manually. However, neither the workbook or worksheet is protected as far as I can tell. I can open, edit, and save without a password and it's not shared; but I can't insert a worksheet. What am I missing?
joerd,
I figured it out. I had locked a few cells and password protected as a test. I placed this out on the network so others would have access and we were playing around with security ideas weeks ago. I forgot to remove the protection when we were finished. I took a stab at passwords for awhile until I got it right. It was something I've never used before or since so blind luck and stupidity has saved my butt again. Now where did I put those lottery numbers.
