1
- #1
cowski
- Apr 23, 2000
- 8,218
A while back someone asked how to get assembly level information into a spreadsheet. Since then I have had the pleasure of working on a BOM in Excel. I worked out a macro to parse out the quantity information and add it to its own column.
How to use:
[I'm using NX2, some items may be different on other versions]
1) change the part name style to "file name"
go to preferences -> assemblies and look near the bottom of the dialog box.
2) in the assembly navigator expand all and pack all (options on the right mouse popup menu)
3) export to spreadsheet (right mouse popup menu)
4) import code into excel
5) run macro
Hope this helps somebody.
How to use:
5) run macro
Code:
Option Explicit
Dim strPartNumber As String
Dim strQuantity As String
Sub Macro1()
Call ParseQuantity
End Sub
Private Sub ParseQuantity()
Dim i As Long
Dim j As Long
'insert quantity column
'change this as needed
Columns("B:B").Select
Selection.Insert Shift:=xlToRight
Range("B1:B1").Select
ActiveCell.Value = "Quantity"
With Selection
.HorizontalAlignment = xlCenter
.VerticalAlignment = xlBottom
.WrapText = False
.Orientation = 0
.AddIndent = False
.ShrinkToFit = False
.MergeCells = False
.NumberFormat = "General"
End With
Columns("B:B").EntireColumn.AutoFit
'select first cell in part number column
Range("A2:A2").Select
'loop through cells that are not empty
'when macro encounters an empty cell it stops
Do Until ActiveCell.Value = ""
strPartNumber = ActiveCell.Text
i = InStr(1, strPartNumber, " x ")
If i = 0 Then
'string not found, quantity = 1
ActiveCell.Offset(0, 1).Activate
ActiveCell.Value = "1"
ActiveCell.Offset(0, -1).Activate
Else
'string found, quantity > 1
j = Len(strPartNumber)
strQuantity = Right(strPartNumber, j - i)
'strip off first 2 characters of quantity string - "x "
strQuantity = Right(strQuantity, Len(strQuantity) - 2)
'strip off last character of part number string (a space)
strPartNumber = Left(strPartNumber, i - 1)
'record part number with quantity stripped off the end
ActiveCell.Value = strPartNumber
'move cell over a column and record quantity
ActiveCell.Value = strQuantity
'move cell back to partnumber column
End If
'move active cell down 1 row
ActiveCell.Offset(1, 0).Activate
Loop
End Sub
