I usually get the loft data to re engineer a part. Sometimes it is so large, that it takes good chunk of the day just entering. Can you import such data thru excel into CATIA, or is there any better sugestion.
hey ferdo, i checked out the link but it converts geometric set already in place in to text file . I need it the other way around. I m not VB savvy so I am not sure if you can reverse the alogirthm somehow, plus I don't even know how to apply any script downloaded to CATIA. I have one that hides all plane in the assembly mode, but still haven't applied it yet also.
do a little search in catia help. I don't have it on right now, but I used this feature to make a curve for an airfoil.
you can specify points, make curves and then surfaces, all from excel.
formatting the data is a different story, but look for the help in catia.
