DeltaCascade
Chemical
In MS-Excel, when drawing PFD's (process flow diagrams) and process block diagrams, using connector lines to join block objects is so much more powerful than just using a plain formatted line. When working to make a finished drawing easy to read, mooving the blocks around to minimize lines crossing each other, etc, is easy, as the connecting lines stretch and bend to maintain their connection between blocks. It's like having the graphics user interface of a high end processs simulator!
Trouble is, there are only 4 line-connections allowed per block. Any way to increase this number? We have more than four lines into and out of blocks and still want to use connectors (instead of lines) to the max.
It's a great feature expandable in capability... Thank you in advance for any ideas (i tried 8 sided figures in Excel, still, even for a four sided object, only 4 points per obnject to connect connector lines
Cheers//
Cheers//
