I am currently working on a 37' long box truss in RISA, top and bottom chords L5x3x1/4 steel, with L2x2x1/4 bracing. I am applying wind and ice loads in which case the top and bottom chords fail. When I switch the chords to Euler buckling members the chords pass. I am not sure if Euler buckling is an accurate assumption to be making in this case or not. When can we consider a member to be Euler controlled as opposed to tens/comp?
Shayne C. Guenther
Shayne C. Guenther
