ETAP Arc Flash Simulation Error
supermanengineer
8
am not able to run the Arc Flash Simulation it is giving me the error:
" Calculation Error: Memory mapped file for source contribution has insufficient size. The file size can be increased by setting the preferences entry No. of Upstream Contributing Branches to a larger number (Max=999)."
However ETAP is able to run the short circuit simulations.
I suspect that is because the SC calc does not have to keep track of individual branch contributions separately as it would in an arc-flash calculations.
Did you try doing what the error message suggested?
There is an option on:
Tools>Preference>Arc Flash> No. of Upstream Contributing Branches
Change the number and it worked..:)
