billbracken
Petroleum
- Feb 19, 2015
- 3
Hello All,
I'm here with the start of a couple projects involving the distribution of water across land via pipeline. Before I start, I need to find the estimated pressure the line will have on it to determine the type of pipe to use for my project. Ideally, i'd like to come up with a formula and/or equation for calculating the pontential pressure the line will run at.
All viables that will be in effect would be;
- vertical height and distance the line will be running
- pump curve
- pipe size
- friction loss of the pipe
- ability to achieve (non-designated) gallons per minute
Without going into too much detail, can we create a formula to determine the psi of the line? If there is any other factors that would have an effect on this, please feel free to add.
- pump curve
- pipe size
