Error when using sol200 for model updating
benkra
Aerospace
DE
Hi guys,
we are trying to update the young's modulus of a simple structure with experimental frequencies using sol200.
However there is one error message remaining that we can't solve:
*** SYSTEM FATAL MESSAGE 3001 (DOPR3)
THE INPUT DATA BLOCK NAMED DYNAMIC AT POSITION 19 DOES NOT EXIST.
USER INFORMATION: THIS ERROR IS CAUSED BY ONE OF THE FOLLOWING:
1. THE DATA BLOCK WAS NEVER CREATED.
2. THE DATA BLOCK WAS DELETED.
3. THE DATA BLOCK IS SPECIFIED ON A TYPE STATEMENT IN THE CURRENT SUBDMAP OR A HIGHER SUBDMAP
BUT THE CURRENT QUALIFIER VALUES DO NOT MATCH
THE QUALIFIER VALUES OF THE DATA BLOCK(S) ON THE DATABASE.
USER ACTION: 1. IF YOU ARE EXECUTING AN MSC.SOFTWARE SUPPLIED SOLUTION SEQUENCE AND NOT USING THE
ALTER EXECUTIVE CONTROL STATEMENT, THEN CHECK FOR BULK DATA AND/OR CASE CONTROL INPUT
ERRORS. IF NO ERRORS CAN BE FOUND, THEN CONTACT MSC.SOFTWARE CLIENT SUPPORT.
2. IF YOU ARE EXECUTING A DMAP PROGRAM NOT SUPPLIED BY MSC.SOFTWARE, THEN FOR DEBUGGING PURPOSES
INSERT STATEMENT DIAGON(20) BEFORE THE MODULE SHOWN ABOVE.
PROGRAMMER INFORMATION: THE FIST NUMBER IS 119 AND SUBROUTINE IS DOPR3
The code is also included below as a file:
ID *
TIME 10
SOL 200 $ OPTIMIZATION
CEND
TITLE = Youngs modulus of real structure
SUBTITLE = Optimization
ECHO = UNSORT
DISP = ALL
STRESS = ALL
METHOD = 1
ANALYSIS = MODES
DESOBJ(MIN) = 11 $ OBJECTIVE FUNCTION DEFINITION
BEGIN BULK
$ ANALYSIS MODEL:
INCLUDE 'Cross4.bdf'
$ DESIGN MODEL:
DTABLE FEXP1 40.1847 FEXP2 116.826
$...Define the design variables
$DESVAR ID LABEL XINIT XLB XUB DELXV
DESVAR 1 YOUNGS 210000. 180000. 240000.
$...Relate the design variables to analysis model properties
$DVPREL1 ID TYPE PID FID PMIN PMAX C0 +
$+ DVIDD1 COEF1 DVID2 COEF2 ...
DVMREL1 1 MAT1 47 E 170000. 250000.
1 1.
$...Identify the analysis responses to be used in the design model
$DRESP1 ID LABEL RTYPE PTYPE REGION ATTA ATTB ATT1 +
$+ ATT2 ...
DRESP2 12 VALU1 101
DTABLE FEXP1
DRESP1 1
DEQATN 101 VAL1(FE1,FR1)=FR1/FE1-1.
DRESP1 1 F1 FREQ 1
DRESP2 13 VALU2 102
DTABLE FEXP2
DRESP1 2
DEQATN 102 VAL2(FE2,FR2)=FR2/FE2-1.
DRESP1 2 F2 FREQ 2
DRESP2 11 RESU 100
DRESP2 12 13
DEQATN 100 RESUL(WERT1,WERT2)=SSQ(WERT1,WERT2)
$ Identify the constraints: no constraints
$...Optional override of design optimization parameters:
DOPTPRM IPRINT 2 DESMAX 10 DELP 0.5 P1 1
P2 15
PARAM POST -1
ENDDATA
The .bdf file works well with sol103 calculations and has about 4000 lines.
We would very much appreciate your help!
Ben
