I'm doing an analysis on an assembly that involves 6 parts. The load is axial and only applies directly to three of them. The other 3 are rings which secure the assembly. When I run the analysis I continue to get an error that say the contact regions create a crack region. Is there anyway to get around this? I can provide the files if anyone has any ideas.
This is HUYNHT98 post:
I have an assembly that has 4 parts and I used Ansys Workbench it worked fine. Then I ran the same Assembly with the same constraints & loads in ProMechanica then I have the error that say the contact regions create a crack between 2 volumes. Then I add more contacts to around adjacent chamfers and rounds then It takes care the crack regions between 2 volumes but it did notrun in ProMechanica for long. It tells me that I have a Fatal Errors and It never passes the pass # 1in ProMechanica. I think everyone has problem with contact analysis in ProMechanica.
