Error when running: "Value too small/large...."
KLee777
I rec'd the following error when trying to run my analysis:
"Value was either too large or too small for a Decimal."
Can anyone please tell me what may have caused this? We can't even get to the report to see what values may be causing the error.
I have uploaded the file in case anyone wants to try to run this.
Thanks.
I suggest you send your inquiry to Codeware technical support. Send your vessel file to support "at" codeware.com
Tom Barsh
Codeware Technical Support
This problem was due to input value g1 for ring-type Appendix 2 flange being less than the g0 value (entered value was 0.0").
Normally COMPRESS validates the inputs and warns the user if g1 < g0 when the input dialog is closed. This function seems to be broken in build 6254. It will be corrected in the next build.
Tom Barsh
