Error in imported file
bigBboris
I have several solids I've imported from Autocad thru IGES, and they have error symbols in feature manager. Tools/Check tells there is a General fault 1.
Is there any way to fix this problem or at least get rid of that error symbol?
Thank you.
If it's a surface you can try to run a Diagnose on the file and maybe it will get rid of the general fault. Otherwise you have to manually get rid of it. You might have to cut out that section and replace it with other surfaces, etc...
There is no easy way to get rid of general faults with a lot of work on your end. But you have to get rid of them or they will haunt you and your part before you finish with it.
Scott Baugh, CSWP [pc2]
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
Thank you.
Diagnosis works.
Still learning.
How do I run a Diagnosis on a file?
jetp1 ... in the Index section of the SW Help file, type import, then click on diagnosis.
[cheers]
Making the best use of this Forum. faq559-716
How to get answers to your SW questions. faq559-1091
Helpful SW websites every user should be aware of. faq559-520
