Error in Etabs while export and import
Ali Abidi
IN
Dear All,
I m working on a low rise residential building and designing in Etabs. When I export and import in e2k file, Reinforcement in column only exceeds about 3 times without any changing in Etabs model. Can anyone explain or check attached Etabs file.
your immediate feedback regarding to the matter subjected will highly be appreciated .
Thanks in Advance
Regard's
Ali
 https://files.engineering.com/getfile.aspx?folder=33843614-1321-4967-bbbf-68e22ab44fbc&file=result.pdf
