I have solve a CREMONA structure. I create the BEAM-3, put the Area, Izz and height. Select model structural, linear, elastic, isotropic.
I create keypoints, lines to link keypoints. Meshtool > divide each line in 10 divisions and finally I mesh.
I set the restrictions and put the forces.
I solve the system and get the right reactions.
The problem is that when I want to see "element solution" I get an error " No data is available for the selected model or data location
specifications"
It's curious because the first time I did it, I could see the element list solution. But now I can't and I haven't modified anything.
Thanks!!
specifications"
Thanks!!
