Equivalent of a671-cc65 pipe
akhilshankar
Industrial
Sep 8, 2016
1
Hai,
I am confused with a671-cc65 grade pipe, because it's not available in local market, and when I searched the material properties I realised this grade are a kind of low-temperature material. So I just want to know is there any equivalent grades of this? Is A333 Gr6 is applicable or not?
Please give a suitable answer.
Akhil
akhilshankar said:
a kind of low temperature material
Take a look at the standard, particularly the title. You will find that it is not solely a "low temperature material." It can be tailored to whatever design conditions pertain. A333 might be a suitable alternative; so might an appropriate grade from API Spec 5L. You haven't stated which class you are looking for. The 2X classes might give you problems in substitution owing to the stress relief requirements.
Steve Jones
Corrosion Management Consultant
All answers are personal opinions only and are in no way connected with any employer.
