I'm working on an application using pneumatics in a plant that will have airborne cement dust. Does anyone have practical tips for what works and what doesn't in this type of environment? I'm especially concerned about the cylinders, valves, bushings, and bearings(esentially anything that moves). The air used will be dry clean air, but there will be dust gathering on the cylinder rods, etc.
I've got some ideas of things that will probably work, but I'd like some practical feedback. Do bellows/boots help? Do cylinders last longer if they are run without lube? Are there special bearing materials that hold up well?
Thanks in advance,
Farmboy
Thanks in advance,
Farmboy
