Is there a way to create specified number of construction points on an elaborate sketch and be equally spaced automatically? (as in a bolt hole pattern)
You can use Transform and give a delta value and use Multiple copies to create the points. This will not add any parameters to keep them spaced as such. IF you sketch construction lines between the points you can add equal length and coincident constraints automatically.
