Gaetan82
Aerospace
- Nov 12, 2011
- 9
Hi, i have a problem when trying to run a model in Nastran ( Sol 101) and hope that someone can help me: the epsilon value that i read in the .f06 file is about 1.70E-4; now, i know that this value is big and that, normally, a good value for epsilon is 10E-9 or smaller. I know also that this value is a measure of numerical accuracy and round off error of a run (101) and that a bigger value evidences a ill-conditioning problem (small perturbations in the system can lead to large changes in the solution);
What are possible cause of this problem ? in a blog i read:
1) high difference in stiffness between adjacent elements in the model.
For istance a mistake in the application of properties ( composites) on a panel done manually ? is it possible ?
Can someone suggest me other possible cause for this type of problem ?
Thank you
Thank you
